by bowman32 » Fri Aug 15, 2008 10:52 am
I have a 1998 pro-v 202 that is seriously under powered, but considering the circumstances for now I need to go with what I have. This boat is set up with a 150 merc (not an EFI,xr6 just a standard carburated 150l). Why the guy I bought this boat from had a 150 on it Ill never know. I am having a planing issue, right when the boat starts to plane it blows out, now if i feather it a little it will plane out, but with 3 people It takes for ever to plane out and I cant keep it from blowing out. It has a 10" blazer jack plate, the prop shaft is 2.5" below the pad, and It has a 14 x 22p raker prop. My top speed with me is 61. Im not necessairly wanting anymore speed just a better hole shot with what I have. yesterday I put a 13 3/4 x 23p trophy plus on it and the hole shot was better (no blowing out) even with 3 people on board but the top speed with just me was 50. It didnt plane out any faster it just did not blow out. I tried this prop with all the plugs in and with them out. It would not even plane out with the plugs out of it. the best It ran was with 2 plugs out. Besides buying a bigger motor does anyone have any suggestions as to what prop I should use and what motor height this set up should be ran at.
