need help with speed on 202
Postby josh blazer » Wed Jul 13, 2011 7:19 pm
I have a 99' 202 with a 200 EFI mercury with a 25 pitch prop. I can get it to turn about 5900 rpms but the best it will run is 63 mph. i need some help getting my speed up other similiar blazers say they gps theres at 69-73 mph. What do i need to try?
josh blazer
Re: need help with speed on 202
Postby tcd » Sat Aug 27, 2011 11:16 am
try raising your motor
tcd
Postby Steven » Thu Jan 19, 2012 8:30 am
You should have to change it as it will not give you more RPM. You can try 625 Elite pro. It will you the real speed experience...
Steven
Postby blazer0928 » Sat Feb 25, 2012 11:33 am
hey i got the same problem. i'm running a 202 with 200 pro max 24 chopper ss prop. mine only tops out at 60 at 6000rpm.
blazer0928
Postby atdh1979 » Sat Feb 25, 2012 10:10 pm
i have a 1998 202 with a 200 mariner mag efi 12in jackplate 1 3/4in below the pad 25 pitch tempest plus, tournament loaded with two people it will gps mid to low 70's turning 5900-6000 rpms, it will run faster with a good chop on the water, sounds like yall may need to play around with some props and jackplate height
atdh1979
Postby blazr190 » Mon Mar 12, 2012 8:55 pm
Do you have a jackplate, and if so how high is your motor, and what is your water pressure guage reading. When I first had my 190 Pro-v I was running a 25 tempest at 6400 rpm's with 200 merc. It took plenty boat time to achieve this, it can be done
blazr190
Postby Whiskyyyyyyy » Sat Apr 28, 2012 9:03 pm
there canbe many reason why your boat is not hitting low 70's i need to know your exact setup up to help you what kind of jackplate are you running? fuel oct.mixed oil you use ect.
Whiskyyyyyyy
Postby blazr190 » Fri Jul 06, 2012 7:51 pm
probably need to raise the motor a little, but keep an eye on your water pressure.
blazr190
