In the hull transducer install, HELP...
Postby back_lash » Fri Sep 19, 2008 11:33 am
I've got a 2000 210 and I'm going to update the electronics and want to put the puck transducer in the hull. I looked last night and don't see a "special" spot to put it. Should I sand the inside bottom of the hull before using the epoxy?
back_lash
Re: In the hull transducer install, HELP...
Postby Skip » Mon Oct 20, 2008 1:36 pm
I also upgraded my electronics recently in my 2005 180ProV. No need to sand unless it is really rough. Be sure to use a slow curing epoxy and weight the transducer down until the epoxy cures. I was told that I may have a minute amount of signal loss but should not be a problem.
Skip
