blazer 210 pro v wiring
Postby bamared » Sat Jul 14, 2012 9:48 am
anyone have a PDF of the dash wiring?
I have a little buzzer that is tied into the ignition key switch, and its tan with a light blue stripe.
There is a purple wire going from ignition switch to buzzer, and back to engine as far as i can tell. the other side of the buzzer has the tan with light blue that doesnt connect to anything. I have tried to ground the tan wire and it just makes a solid beeeeeeeeeeeeeeeeeeep. If its just left the way it was, it makes a beep beep beep beep beeep beep beep. until I turn the motor off.
things I have checked.
Disconnected the water oil filter wire, no change.
im getting HOT water out of the pee hole.
the tank on the engine for oil resivour is full and the cap is working properly. I checked it for ohms with cap removed and shorts to ground, and moved the float up and I get resistance so i know its good.
havent ran the engine in about a year, and last year had the water pump replaced, new sport master lower unit installed and dealer serviced. it just started this mess and driving me nuts.
bamared
