How bad are the Yam HPDI big blocs?
Postby Marco » Thu Mar 05, 2009 9:35 am
I would like to purchase a pro v 2004 with a HPDI 300HP Yamaha, but have heard they have many problems with the 225 250 and 300 HPDI. They take to much oil, heads blow, some compare it to the FITCH (worst motor ever). Any bad luck with your HPDI 2003, 2004 ,2005?
Thanks for your help
Marco
Marco
Re: How bad are the Yam HPDI big blocs?
Postby ktdore » Mon Mar 09, 2009 12:24 pm
I have an 04 300 vmax hpdi with close to 100 hrs. and never had a problem. As far as the oil thing, there is a service bulletin on the oil pump to be replaced. There is a code on the pump arm. Any dealer can check it to see if it needs to be replaced. I think they are great motors.. :D
2220 Pro 300 HPDI Vmax
ktdore
Postby blazerman809 » Thu Mar 19, 2009 4:39 pm
I Dont Have any problems with my 06 V-Max 250, The Boat Runs Strong....
Patrick Burkhart
'06 202 Pro-V
Yamaha 250 HPDI
"Smallmouth Heaven"
Florence, Alabama
blazerman809
Postby Isle of Palms » Thu Apr 02, 2009 11:38 am
Unless it's already blown up once or twice and has a series 2 powerhead on it I wouldnt buy that one. The oil pump recall increases the amount of oil the engine gets at certain rpm's (to help with their reliability issues) so you would notice an increase in consumption. The new series 2 3.3l hpdi's are good so far.
Isle of Palms
Postby blazer210 » Mon Oct 12, 2009 12:08 am
Isle of Palms wrote:Unless it's already blown up once or twice and has a series 2 powerhead on it I wouldnt buy that one. The oil pump recall increases the amount of oil the engine gets at certain rpm's (to help with their reliability issues) so you would notice an increase in consumption. The new series 2 3.3l hpdi's are good so far.
what does the series 2 have on it that my yamaha doesn't? this is the guys boat that jeff worked on,he installed a phase 3 kit.
blazer210
