Need help with chimewalk
Postby Bear51 » Fri Aug 28, 2009 9:36 am
Ihave a 2008 190 prov with 200 opti 25 temp prop. Can someone tell me where to start with mtor height and how much of the chimewalk that I can expect to be able to adjust out and what speed I should expect to see :)
Bear51
Re: Need help with chimewalk
Postby Rebel1 » Sun Aug 30, 2009 5:05 pm
You need to start at about 1 3/4in. below the pad and come up till you lose water pressure or gain rpm but lose speed. This combo should see about 73-75 depending on load, set-up, and driver ability.
Jason Carnley
08' 202 DC/ Yamaha 300 HDPI
Turbo Props Pro Staff
Rebel1
Postby Bear51 » Mon Aug 31, 2009 7:05 am
At what point on the motor do I take my measurement at the point on the nosecone or somewhere else.
Bear51
Postby blazerbrian » Mon Aug 31, 2009 10:00 am
Take your measurement at the center of the prop shaft 8-)
blazerbrian
