2220 Fisherman Prop Setup
Postby PCGinn » Fri Mar 21, 2008 7:37 am
I bought a 2003 2220 Fisherman with a 200 VMax(0X66) last year. I know alot of yall have a similar setup.
What size/pitch prop. are yall running on a similar setup? My goal is the best shallow water start I can get. Fishing shallow means more to me than doing 50+.
PCGinn
Re: 2220 Fisherman Prop Setup
Postby sags » Fri Mar 21, 2008 10:29 am
PC Ginn,
We run the same set-up with a K-Top plus trim tabs. The best prop we found has been the powertech OFX 4 blade 19 pitch. When you hit it real hard with the jackplate up all the way it will throw you out of the back of the boat if your not holding on! It will come out real flat with the tabs down and will run 54-55 GPS with it trimed out not bad for a 4 blade and a top on the boat.
P.S. This is with a 6" jackplate not a 10"
BB 2220 Fisherman, V-Max 200, PT OFX 20 4 Blade, K-Top
Fishing for the Slam in Texas
sags
Postby gdup » Wed Mar 26, 2008 7:23 pm
Sags, What is the size of your well 13 3/4"? x 19. Where can I find a power tech prop.
2220Pro w/ 200HPDI, 80#MinnKota, 24volt onboard charger, Garman 541s, And a Huge Smile
gdup
Postby sags » Fri Mar 28, 2008 3:49 am
Sorry for the late reply the OFX is a 15 1/4" X 19 pitch 4 bladed prop. The best place I've found to get them is from pitstop marine go to their web site and you might have to call the guy and he'll order it for you, it was drop shipped to my house.
sags
Postby gdup » Fri Mar 28, 2008 9:44 am
Thanks Sags, I will check into that.
gdup
