2220 Fisherman w/200 Yamaha vmax 2003
Postby bbay37 » Thu Mar 27, 2008 10:48 am
I purchased a 2220 Fisherman w/200 Yamaha vmax 2003 model last year. It tops out at 49mph on the gps (Full tank/2 people). It came with a 23P yamaha pro series prop (3 blade). Had it reworked to see if I could get better performance. No luck. Is this the correct prop for this set up? Fuel economy is not very good also. Should I be getting more speed? Thanks.
bbay37
Re: 2220 Fisherman w/200 Yamaha vmax 2003
Postby neverenough » Thu Mar 27, 2008 6:52 pm
what is your rpms? WOT
Postby sags » Fri Mar 28, 2008 3:58 am
BBay37, that doesn't sound right but like was asked what's your rpm's at WOT? When I first got our 2003 they had a pro 21 prop on it and the thing would fly but that was with a jack plate and we could play with the height of the motor. There could be a number of things going on there as to why only 49 MPH with that 23. Check the topic below about the same boat and the comments
BB 2220 Fisherman, V-Max 200, PT OFX 20 4 Blade, K-Top
Fishing for the Slam in Texas
sags
Postby bbay37 » Fri Mar 28, 2008 7:16 am
WOT is 5300 rpms. I do not run a jackplate.
bbay37
Postby neverenough » Fri Mar 28, 2008 11:33 am
no jack plate could be bogging you down a bit @ WOT. you should be running that dude up closer to 6000rpm. i do not really care for the yamaha props that much. you might try a mercury prop even in the same pitch, or go a little lower in pitch. if it is only running @ 5300 it isn't even producing maximum hp yet. find a dealer that will let you run a few if you buy from them. i love the tempest+
