I have a 2170 with a f-150 2006 4 stroke yammie. This past weekend
I hit something submerged below the surface. It broke off part of the
cavitation plate on the port side. Fortunately it did not do any serious
damage. A local prop shop does this kind of work. First they have to find
a used lower unit casing & go from there.
One thing the owner mentioned was my prop got nicked up & needed to
be re-worked. He also asked what rpm's it turned wide open & trimmed up.
When I told him 5100 he asked if I meant 6100. I have a 19 inch pitch.
He said that motor for optimum performance should turn 5800-6100 rpm's
6100 being the ideal number with the normal load. The local yamaha
mechanic agreed. So I want to know what size prop you are running
on your 2170 or any of the 22 footers.
