anchor drain 06 2420 pro
Postby terry prejean » Tue May 11, 2010 4:49 pm
the anchor drain has come loose 3 times and has benn replaced 3 times. ordered new drain and is no longer avaliable.I was sent a replacement that bolts to the hull. I guess i will have to plug anchor drain. Any one else have possible fix.
terry prejean
Re: anchor drain 06 2420 pro
Postby fisheye48 » Tue May 11, 2010 5:10 pm
put some 5200 on the bolts and screw them back in
fisheye48
Postby rhino » Tue Jun 15, 2010 12:00 am
What ? That scupper on the bow is just coming off ?
Postby blazer butch » Wed Jun 16, 2010 8:28 pm
blazer changed to the style that screws on the one you had on your boat was a two peice deal that if bumped or rubbed on, the right way, could wiggle itself loose. the new one is a lower profile and if installed properly will never come off.
blazer butch
Postby rhino » Wed Jun 23, 2010 11:13 am
What is behind that drain ? I'm fixin to fill mine up with silicone , I'm tired of water coming up in it into the bilge . I don't think the bilge pump should run that much .
