Battery Compartment Draining
Postby RickW » Wed May 19, 2010 9:03 pm
The battery compartment on my 2220 Pro is holding water. How are these compartments supposed to drain?
RickW
Re: Battery Compartment Draining
Postby neverenough » Fri May 21, 2010 6:28 am
there should be a drain hole thru the stringer allowing it to drain into the bilge. it can be unclogged by running a piece of single strand wire thru it.
Postby huntr52 » Mon May 31, 2010 1:07 pm
I had the same in my 2220. There are holes drilled in the stringer separating that area from the bilge but they are small. I routed out the holes to twice the size that were there and still sometimes I find water collecting?? Thinking about drilling them out even larger.
huntr52
