starline trailer/axle problems
Postby baybreaker » Fri Jul 16, 2010 5:53 am
I have not been succesful in finding a solution for my tires wearing out on my trailer,, blazer bay model 2020 3500 lb axle with 15 inch radial tires has anyone heard of a way to cut/ weld bend this axle to correct the toe in problem any help would be great.
baybreaker
Re: starline trailer/axle problems
Postby blazerbay2020 » Sat Jul 17, 2010 5:30 am
Hi,
Unfortunately I have alot of experience on this matter. I to have a 2020 on a starline trailer. I've been through 3 different axles and finally a new trailer. If you would like I can contact you and give you the story on how my problem was resolved.
Leigh Veron
Leigh Veron
2007 Blazer Bay 2020
2007 Yamaha 200Z HPDI
Gonzales, LA
blazerbay2020
Postby rhino » Sun Jul 18, 2010 6:20 pm
Tomahawk Trailers takes over Starline
by tomahawktrailers » Mon Jan 04, 2010 6:52 pm
Tomahawk Trailers, Inc. is the new builder of Starline trailers (effective 10/2009).
If we can be of any assistance to you regarding warranty work, repairs/maintenance, or general questions regarding components of your existing Starline trailer, please feel free to contact us.
Richard Hardy
Milton, Florida
tomahawktrailers@gmail.com
(850) 723-0693tomahawktrailers
Private messageE-mail tomahawktrailers
Go back to pg4 original msg.
Same people , different name . They should still honor their warranty
Postby baybreaker » Sun Jul 18, 2010 7:46 pm
richard,, i did contact you remember i sent you 6 pictures of my trailer no response,,, blazer bay said they were not responsible for starline trailers any longer , will find a solution somewhere but hope the companys realize that with each negitive post it sure sticks in peoples mind .
baybreaker
Postby arriane04 » Fri Sep 17, 2010 2:10 am
It looks like an alignment problem. You should measure from the axle on each side making sure that you pull from the same spot on the hitch and use the same edge of the tape. If it's not alignment, the axle may be bent so you better balance the tire.
arriane04
Postby baybreaker » Mon Sep 27, 2010 7:35 pm
I did find my trailer axle was 1 inch out of square from the back of the boat moved it up 1 inch bought 2 new 8 ply radial tires that are higher rating than those 6 ply so now we will see how the wearing does now also had the tires balanced , if this dosent solve the problem then the boat is too much weight for the 6000 lb axle ,,, boat weighs 3700 lbs
baybreaker
Postby gilly » Thu Oct 07, 2010 10:06 am
Mr. Vernon i would love information on the starline trailer. I have a 2009 Blazer bay 2020, its a good boat but have gone through too many tires.
gilly
Postby baybreaker » Sat Oct 30, 2010 8:18 am
so far my problem has been solved by putting 8 ply tires on and putting 60 lbs of air in the tires trailer was one inch out of square , so far so good ,,my boat motor,trailer weighs 3700 lbs and i have 6000 single axle ,,torsion bar ,, 15 inch tires, tires wear rated for 1700 lbs so i moved up with those 8 ply 2400 lbs rated
baybreaker
