Horn Issue 2220 fisherman
Postby dc2220fisherman » Wed Jul 28, 2010 4:36 pm
Im having a problem with my horn. When my aerator kicks on in the livewell you can hear the horn being applied very faintly, anyone have that problem before, the boat is at duvics right now, and vince told me that he always has this problem with the blazers, any ideas, fixes?
dc2220fisherman
Re: Horn Issue 2220 fisherman
Postby stms26 » Thu Jul 29, 2010 2:21 pm
I have had a similar problem with the horn, but it was after a good rain or wash. I never noticed it happen when the aerator kicked on. The last time it happened, I took the switch apart and packed it with die electric grease to keep moisture out. Since doing this i haven't heard it doing it again.
stms26
Postby dc2220fisherman » Thu Jul 29, 2010 3:07 pm
Thanks man, i will be sure to give that a try.
dc2220fisherman
Postby Gman » Mon Aug 02, 2010 3:31 pm
Had the same problem. Replaced the switch and problem was solved.
Gman
Postby dc2220fisherman » Mon Aug 02, 2010 5:06 pm
Thanks for the input guys, replaced the switch and it still did it, replaced the horn, still did it, wound up having to go with an aftermarket horn to take care of the problem, now i washed the boat yesterday, found large crack in rod locker, spider cracks in gel coat at transom and on the sealing surface for the back battery compartment, nothing but problems is what this boat seems to bring, keep in mind i only have 23 hours on this boat, 2010! Blazer needs to do something new because there quality is just lacking.
dc2220fisherman
