2420 Blazer Bay
2420 Blazer Bay
Postby robbidw » Thu Aug 12, 2010 4:14 am
I have a one year old 2420, ever since it was new I noticed the beilge pump would come on and pump water for a few minutes and cut off, this would happen about every 10 to 15 minutes, I keep the boat in a boat house on a lift out of the water so I didn't pay much attention to it but thought something had to be wrong, last week I took it Ark. where it stayed in the water behind the house boat, for two mornings after sitting in the calm water over the night the back of the boat and bielge was full of water, after bailing it out because I guess the bielge pump burned up we took and put it on the trailer, we left a good bit of water in the hull to see if would could see where the water would be coming out of, the hull had no water leaking out of it, it is in the shop now in Louisiana but they are not :cry: sure where it could be coming from, any suggestions
robbidw
Re: 2420 Blazer Bay
Postby rhino » Fri Aug 13, 2010 2:09 pm
I'd check the anchor locker drain , you can go back and check the posts regarding the subect
