Horn question on 2220 Pro
Postby johnhiggins » Mon Jan 24, 2011 7:34 am
I awoke the other night with the sound of my horn blowing about half volume on my boat.
I could press the horn and it would blow full and when I released it it would not go off all the way, it contiuned to blow about half until I shut the power off.
Looking for help in determining why it is doing this.
Thanks for any ideas to check.
johnhiggins
Re: Horn question on 2220 Pro
Postby Gman » Fri Jan 28, 2011 10:35 am
Had the same problem. Change out your rocker switch.
Gman
Postby johnhiggins » Sat Jan 29, 2011 4:35 pm
I actually cut one of the horn leads just to stop the noise.
My son had a problem on his boat where mositure had gotten in the switch.
I had just washed my boat the day before and he said water probably got into the switch.
I let it dry out and reconnected the wire and it worked. No horn blaring.
johnhiggins
Postby jkolman » Sat Feb 12, 2011 8:37 pm
I had the same problem. Changed out the switch and the problem went away. I had prurchased the switch from Blazer for around $6.
jkolman
