2220 Top Speed
Re: 2220 Top Speed
Postby Cyndyr » Thu Aug 27, 2009 12:57 pm
Does a jackplate lower the motor from where it would normally sit with no jackplate? I figured a jack was only good for raising the motor higher.
Cyndyr
Re: 2220 Top Speed
Postby neverenough » Thu Aug 27, 2009 5:22 pm
yes, it will give you a range of running height. for different water conditions you will get better performance at different heights.
Re: 2220 Top Speed
Postby dc2220fisherman » Thu Apr 15, 2010 7:32 pm
i have a 2220 fisherman with a suzuki df200 four stroke, no jackplate, with 20 gals of fuel, light fishing gear and 2 people i am getting 58mph on gps at 5800rpms.
dc2220fisherman
Re: 2220 Top Speed
Postby neverenough » Fri Apr 16, 2010 8:45 am
dc2220fisherman wrote:i have a 2220 fisherman with a suzuki df200 four stroke, no jackplate, with 20 gals of fuel, light fishing gear and 2 people i am getting 58mph on gps at 5800rpms.
that is alot more than is expected out of that rig.
Re: 2220 Top Speed
Postby dc2220fisherman » Fri Apr 16, 2010 5:58 pm
yea thats what they told me at the dealer also, couldnt believe it myself.
dc2220fisherman
Re: 2220 Top Speed
Postby fisheye48 » Fri Apr 16, 2010 8:32 pm
so your boat has 50 less hp on it that mine and runs the same speed loaded??? pics of the GPS or it didnt happen
fisheye48
Re: 2220 Top Speed
Postby dc2220fisherman » Sat Apr 17, 2010 9:18 am
Ok once i get the boat back from blazer due to already having a cracked transom i will gladly post.
dc2220fisherman
Re: 2220 Top Speed
Postby rorgero » Sat Apr 17, 2010 2:50 pm
That impressive, must of had a nice wind and tide moving with you. Put 60 gallon of fuel and she'll slow down. Just wondering what pitch are you running on the prop.of that DF 200?
rorgero
Re: 2220 Top Speed
Postby Capt. Eric » Sat Apr 17, 2010 9:50 pm
I run a 2420 that had a yamaha 300hpdi on it until it was stolen over the holidays. That motor ran perfectly and with a stock 14-1/4 x 23 saltwater series prop the boat would run 58-60 mph. That was with 40 gallons of fuel, 2 full grown men, trolling motor, 4 optima batteries and our gear. Cruise was 40 mph @ 4000 rpm. I have had my boat re-powered with a 2010 suzuki df 250. I had my mechanic break in the motor since I drove it from Texas to Florida to have the work done,(he is the best mechanic), and am not picking it up until May. After the break in period was done, and he could really run the boat, he ran it 45 mph @ 4000 rpm with virtually the same load. Now I was not on the boat to verify these numbers, but he knows how to run a boat and would have no reason to exaggerate these figures. I do know that the prop is a 16 x 24.5 suzuki. This is a much larger prop in pitch and diameter, and he says the boat jumps on plane almost instantly. Suzuki outboards are larger in displacement, and have a lower gear ratio that allows them to turn a larger prop. More torque. I am picking the boat up in Pensacola and will be spending a week there fishing the first week of May. After I personally get some real numbers, I will post them with a comparison against my yamaha 300. I will also post a few picks of the GPS.
Capt. Eric D. Lucas
reelflysportfishing.com
Capt. Eric
Re: 2220 Top Speed
Postby dc2220fisherman » Sun Apr 18, 2010 1:57 pm
i believe i am running a 16x21.5, not 100 percent on that until i get it back, but same with my 2220 it jumps on a wave right away, lightyears difference from my ranger 482v
dc2220fisherman
PreviousNext
