190 setup question
190 setup question
Postby blazr190 » Fri May 15, 2009 9:48 pm
I am currently running a 190 pro-V single console with 225 merc, and Titus lower unit. I am looking at purchasing an over hub prop. I am looking at either a 26 Mazco Re3 or 26 Merc chopper. Never tried an over hub prop before. Can't wait to see the difference. If anyone has other suggestions, I am open to them.
blazr190
Re: 190 setup question
Postby colreb2000 » Thu Jun 04, 2009 4:16 pm
I'm curious....do you have a 2.5 ltr 225 Promax or X....or the 225 3.0 ltr?
Nathan Martin
Lucedale, MS
'96 190 Pro-V/'97 175+ Merc EFI
colreb2000
Postby blazr190 » Mon Jun 08, 2009 9:40 pm
I have the 2.5 225.
blazr190
Postby blazer9 » Tue Jun 30, 2009 1:41 am
i would like to see it perform. I have a 1992 190 pro v single console with a 1991 xr4. It runs really good with a 24 laser 2 WOT 5900.
blazer9
Postby blazr190 » Thu Jul 09, 2009 6:51 pm
I have tried the 26 chopper with this setup and it was pretty good, the rpm's were a little high though. I did not have GPS to check the speed, but I turned 6800 rpm and was moving pretty good. My son has a 28 chopper that I am going to try also. I ran the Mazco RE3 27 pitch and rpm's were the same. I was on fishing trip last weekend and propshaft broke, ruined lower unit. I have sportsmaster lower unit on the way. Maybe this will be a little diferent. Right now my motor is 1.5" above the pad.
blazr190
Postby blazr190 » Wed Sep 02, 2009 4:54 pm
Well, I have sportsmaster l/u on the boat. My jackplate is now set at 3/4" above the pad, 1-1/2 was a bit high. It runs great. The 26 chopper had one of the blades out a little so I got it worked. Now I have great bow lift, the boat is fun to drive.
blazr190
Postby blazerbrian » Fri Sep 04, 2009 10:51 am
8-) Good deal 8-) glad you got her going
blazerbrian
Postby blazr190 » Wed Oct 07, 2009 7:00 am
Yes. I pays to ask questions with someone that has been through the same problems.
blazr190
