new member transducer install
Postby 22protower » Sun May 01, 2011 8:35 am
sold my 21 foot skiff and purchased a 2005 22 pro. It has a small garmin with a thru hull transducer works great. I have a hummingbird 997c with an external tranducer. Is there a good place to mount the transducer?
The other question I have is the rear port fish box does not drain completely. Ay tricks I should know?
22protower
Re: new member transducer install
Postby gdup » Sat May 14, 2011 1:09 pm
Get a inhull transducer. It will shoot thur the hull.
To drain the live well, After cleaning boat, I take the water hose and stick it in the drain for a second or two. Then remove the hose. It gets the drain started and totally drains. 8-)
2220Pro w/ 200HPDI, 80#MinnKota, 24volt onboard charger, Garman 541s, And a Huge Smile
gdup
