2020?
2020?
Postby Groman » Fri Dec 07, 2007 4:07 pm
Why hasn't this model been included on the website? I have seen a few around, but not been able to find any specs.
Groman
Re: 2020?
Postby Blazer Johnnie » Fri Dec 07, 2007 5:59 pm
It was accidently omitted from the site. I should be on there by next week.
Blazer Johnnie :oops:
Blazer Johnnie
Site Admin
Re: 2020?
Postby Groman » Fri Dec 07, 2007 7:38 pm
Thanks.
Much better looking site BTW.
Groman
Re: 2020?
Postby natelauscg » Sat Dec 08, 2007 9:34 pm
groman this is nate. I have a 2020 if you have any questions ill answer them if i can.
natelauscg
Location: beaumont, tx hometown-marrero and still fish lafitte,la often
Re: 2020?
Postby Groman » Mon Dec 10, 2007 9:29 am
Thanks Nate.
What are you pushing yours with? And what kind of numbers do you see?
Most I have seen have 150s on them. I have only seen one with a 200 HPDI.
Groman
Re: 2020?
Postby bayspec » Mon Dec 10, 2007 5:33 pm
Groman,
I have the 2020 with the 200 HPDI. I also test drove the 2020 with the 150 Yami 4-stroke. Both engines were green during dealer break-in, but the numbers during initial testing with two people and light fuel were as follows: The 150F had good hole shot and topped out @ about 50 mph turning 5800-5900 rpm. Running about 4500 rpm showed about 35 mph. The 200Z topped out at 58 mph turning 5800 rpm and ran 40 mph at 4200 rpm. Needless to say the hole shot was great. I went with the 200z for the additional umph and only 7 pounds of weight gain. In addition, I was trying to get about 40 mph and in the 4K rpm range. With full fuel and fishing load, the 200z is showing about 40 mph at 4300 rpm and a top speed @ 55 mph @ 5600 rpm. These are numbers on a still green engine with less than 10 hours. The 150F was turning the new 19" pitch Yamaha Reliance prop and the 200z was turning the 21" prop. Hope this helps anyone out there.
bayspec
Re: 2020?
Postby Groman » Mon Dec 10, 2007 7:48 pm
bayspec, thanks for the information!
Groman
Re: 2020?
Postby Groman » Tue Dec 11, 2007 3:28 pm
bayspec,
One more question if you don't mind. Do you have a jackplate on your boat? If so what kind?
I guess that is more than one question :D
Groman
Re: 2020?
Postby bayspec » Tue Dec 11, 2007 4:09 pm
Yes, it is a 10" Bob's Hydraulic jack plate. Fortunately, just one answer.
bayspec
Re: 2020?
Postby natelauscg » Tue Dec 11, 2007 9:49 pm
Groman,
I have the 150 4-stroke yamaha on my boat with a manual jack plate, I got it up to 52mph with another person and 3/4 fuel on calm water and 19 pitch prop.
natelauscg
Next
